Plastic NM Connectors
Old 08-02-14, 06:56 AM
B
Any opinions on using those new plastic NM connectors over the old traditional metal connectors?
Old 08-02-14, 07:08 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Not sure what you mean by "old" and "new". Can you expound a little?
Old 08-02-14, 07:17 AM
W
Received 1 Upvote on 1 Post
I like them. Just like anything, it has good and bad points.
Old 08-02-14, 07:23 AM
they are nice. they add a bit of insulation also.
Old 08-02-14, 07:54 AM
Received 3,419 Upvotes on 3,065 Posts
Which plastic connectors are you referring to.
Old 08-02-14, 08:05 AM
chandler's Avatar
I can't comment since I don't know what you are referring to. Lack of clairvoyance, I guess
If you are referring to box connectors as Pete showed, then yes, they are super.
Old 08-02-14, 08:52 AM
B
Old = metal with screws
New = plastic push in's
Old 08-02-14, 08:55 AM
B
The good?
The bad?
Would love to hear specifics
Old 08-02-14, 08:59 AM
B
The black plastic connector on the left
Old 08-02-14, 09:51 AM
chandler's Avatar
They add insulation between the cable casing and panel, not that it is needed. They are a "one way" application so the cables don't pull out. They are fast to install. They are cheap. They don't weigh much. That enough?
Old 08-02-14, 02:20 PM
Tolyn Ironhand's Avatar
Received 672 Upvotes on 570 Posts
I like the black ones for the reasons Chandler has outlined. I do not like the blue ones as they are a one shot deal and are difficult to undo if needed.
Old 08-02-14, 05:53 PM
CasualJoe's Avatar
Received 173 Upvotes on 156 Posts
It's all personal preference; I prefer the old school metal connectors with screws.
Old 08-03-14, 11:01 AM
pcboss's Avatar
Received 163 Upvotes on 142 Posts
The black plastic are easy to use and inexpensive. They also cannot be overtightened like the screw type. They cable can be removed if needed by spreading the tabs slightly and pulling the cable out.
I hate the blue ones.
