Quad tandem
Old 08-02-14, 08:30 AM
T
Quad tandem
Siemens Q23050CT2 One 30-Amp One 50-Amp Double Pole Circuit Breaker:Amazon:Home Improvement
Would this be ok to use in a panel for two 240v circuits...one for 50a range and one for 30a hot water heater? What are your opinions of these quad 240v breakers?
Old 08-02-14, 08:41 AM
they work ...but you have extra heat buildup in a 2 in space. do you have 4 full size 1-pole 15 or 20 amp breakers that you could change out with thin ones. then you could use a full size 230 and 250 breaker. do your best to keep the larger breakers full size.
Old 08-02-14, 09:02 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
I see these often in a cooktop/oven situation where they are split from a single stand alone installation. Never known of a failure, but heat could be a long range problem.
Old 08-02-14, 10:51 AM
A
Received 92 Upvotes on 84 Posts
Other thing is most of these Siemens panels have a 110 amp limit per stab when using tandem breakers. This puts 80 per stab so you can't put a 20 tandem on the other side.
Old 08-02-14, 06:05 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
These are not quad tandem breakers, just quad. Using the quad breaker in the link would be Ok if your panel is a Siemens and the panel will accept quads and tandems, not all Siemens panels will accept them.
