Reload this Page >
hi there! Can I somehow power a small light off of this battery?
Old 08-02-14, 12:48 PM
I
hi there, I work in valet, and I am trying to solve our peripheral power requirements for our small podium, I have everything figured out but the one last thing I need to do, is power a small LED lamp, which is charged and can operate while plugged in via a normal cell phone type plugin charger.
we have this large battery, which powers solely our backlit valet sign, I was thinking that I could somehow connect our USB charger for the small lamp on to this battery and then power both simultaneously, does anyone have any solutions for accomplishing this? I am fairly handy, but electrical questions I always need help with.
If anyone can help out with this question, I would greatly appreciate it.
Here is the battery.
http://i20.photobucket.com/albums/b2...pslosps0v2.jpg
Thanks in advance!
Old 08-02-14, 01:08 PM
P
Received 2,102 Upvotes on 1,882 Posts
I edited your post so the picture appears.
Yes, powering an LED from a battery is very easy.
Next, you'll have to determine what is a "normal cell phone charger plug". Then I have to ask why it needs to have a plug and socket and why it must be that type?
Most phones these days use a USB based connection which is 5 VDC. The battery in your picture is 12 volts. While you technically can feed 12 volts to a USB socket it is just asking for trouble. If you must have a USB socket I would install a transformer to lower the voltage and create a proper USB charging port. Or, to keep things simple just power an LED light with 12 volts.
Old 08-02-14, 01:13 PM
Received 3,877 Upvotes on 3,475 Posts
All you need is a 12vdc to USB adapter. If you put what I've underlined into your search bar you'll get pages of them. I posted one such link below.
DC-DC 12V to 5V 24V to 5V Step Down Module Voltage Regulator with USB Cable
Old 08-02-14, 01:55 PM
I
My apologies, it is exactly like this charger, shown is iPhone charger, but led lamp charger is the same, 2 prong to usb.
http://i20.photobucket.com/albums/b2...psgfdixe0a.jpg
Old 08-02-14, 02:04 PM
You will need to unplug that charger and use the 12v to USB in its place.
Old 08-02-14, 03:53 PM
I
Ok so one of these will do! Right? Thanks.
Just connect positive and negative to battery terminals right?
Old 08-02-14, 04:16 PM
Gunguy45's Avatar
Super Moderator
Received 6 Upvotes on 6 Posts
Thats all it takes. Simple hookup.
