25 amp breakers
25 amp breakers
Most of the single pole 120v breakers in my panel are 20 amp ..Do they make a 25 amp single
With some companies you can special order in between sizes.
Basically the size of the wire dictates the largest sized breaker you can use.
What size wire do you intend to use on this 25A circuit?
Is the 25A circuit protecting HVAC equipment?
edit - p.s.- Are you proposing a grid-tied inverter setup? Please be more specific with your intentions here?
