Reload this Page >
Can I put two 30 Amp receptacles in parallel on a single 30 Amp breaker?
Old 08-03-14, 12:22 PM
Z
Residential, but home office/network application.
I'm looking to install two large UPS batteries but I only have one spot left in my breaker box, so I can only fit one single-pole 30 Amp breaker. I assume these UPS boxes use the high amperage to quickly charge the batteries.
10 gauge wire of course.
If not, I guess I will have to install a sub panel.
Old 08-03-14, 12:39 PM
W
Received 1 Upvote on 1 Post
It's possible your panel will accept tandems.
Can you post the brand and model # of your panel?
Old 08-03-14, 01:05 PM
How much do the UPS units draw? What you're proposing will work fine unless the total amperage requirements would cause the breaker to trip. Continuous load on a 30 amp breaker (or any breaker for that matter) can only be 80% of the rating found this case the 2 UPSs couldn't draw more than 24 A continuously.
