Garbage Disposal Re-Install
Old 08-03-14, 12:46 PM
K
Greetings--Feeling kind of dopey--Installed new sink/reinstalled the disposal, thought I had re-wired the same way, but no. Line is on separate cirucuit. Line comes in from under sink. Switch from top of counter going down to disposal. Can I wire this to join wires in disposal so it can be switched from switch? Or, do I need to run the power line up to switch? Thanks for the assistance!
Kevin
Old 08-03-14, 12:57 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
It is hard to wire a switch loop in the small wiring compartment of the disposal. What colors of wires do you have at the switch and how many?
Old 08-03-14, 01:04 PM
K
Original set up which was working before un-install. ? Single pole switch with one (1) neutral/white and one (1) black/hot line going down to disposal. No power source going into switch. Power source coming up from basement is the same.
Old 08-03-14, 01:55 PM
W
Received 1 Upvote on 1 Post
You will need a junction box.
The black from the power source will be wire nutted to the white going to the switch.
The white wire from the power source will go to the white wire on the disposal.
The black wire from the switch will go the black wire on the disposal.
All grounds tied together.
Old 08-03-14, 01:58 PM
Handyone's Avatar
All these cables/wires you speak of are in boxes, correct?
You didn't have Romex cable going into old disposal did you?
This is a pretty simple wiring job if we know this.
You should have 2 boxes, one under sink and one at switch.
Box under sink should have 2 blacks and 2 whites.
Switch box should have 1 black and 1 white.
What we need to know is did your old disposal have a power cord going into a receptacle under sink??
Old 08-03-14, 02:20 PM
ray2047's Avatar
Usual way now days is to put a receptacle under the sink and a cord set on the garbage disposal.
Old 08-03-14, 02:45 PM
K
Same disposer-I just unwired the disposal and am re-installing into new sink. No box under sink. Didn't have when it was originally wired-Both switch wires and "power" wires join in at the base of the Badger 9--I was going to wire per previous poster's suggestion. I can
Old 08-03-14, 03:09 PM
Handyone's Avatar
OK, But add a cord and receptacle. It sounds like you know how to do it.
Just take what wirenut said and apply the wiring technique to the receptacle.
Old 08-03-14, 03:24 PM
ray2047's Avatar
Just surface mount a box on the wall over where the cables come out.
Note latest code may require a GFCI protected receptacle. Check with your AHJ.
Old 08-03-14, 03:25 PM
K
You win (wirenut). No junction box needed. Just harnessed the wires per your direction (which is what I was not able to figure out) and tested, ran like a charm. Thank-you so much !!
Old 08-03-14, 03:28 PM
pcboss's Avatar
I hope that was just for testing purposes. The splices need to be contained in a box.
Old 08-03-14, 03:38 PM
Handyone's Avatar
Just for the record kevmel,
You need a 3-Prong cord attached to disposal, properly grounded at disposal EG screw.
Receptacle box, both receptacle and box grounded.
Switch, grounded.
If you can wire this outside the boxes, you can wire it inside the boxes and do a safe (and good looking) job.
