L5-30 on 15 amp line in work shop
Old 08-05-14, 07:21 AM
K
Received 1 Upvote on 1 Post
I would like to add 2 L5-30 twist receptacles in my basement work area and have a twist lock extension cord that I can plug in to either outlet.
They would be powered by 120v 15 amp lines, the L5-30 is a 30 amp plug, would that be any code faux pas using that plug on a 15amp line?
I just want the twist lock features and can get the 5-30 plug and receptacle for a fraction of the cost of the other twist lock options.
Thank you,
Old 08-05-14, 08:29 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
A L5-30P is a plug and a L5-30R is a receptacle.
It's a code violation if that's what you mean.
Old 08-05-14, 09:17 AM
K
Thank you CasualJoe,
The L5-30R and P as a kit are less than just a 15amp twist plug alone locally, hence the temptation.
I will look at other options.
