Reload this Page >
inside, an outdoor, Brick Pillar wiring to light and outlet
Old 08-05-14, 08:22 AM
F
Hello all,
Iím installing an outdoor patio, I will have a few brick columns Name:  1a sm.jpg
that I plan on putting a some clam-shell lights and an electrical outdoor outlet.
I have used ĺ PVC conduit that comes up out of the ground into the inside area of the pillar. Name:  2a sm.jpg
My question is what do I need or should use after the end of the pipe coming out of the ground to go to the outlet if anything at all? And I will have a 4x4 post coming out of the center of the pillar to an outdoor post mounted light.
Do I need to have the wires encased all the way into the outlet when they are inside the pillar?
Thanks for your comments
Old 08-05-14, 08:29 AM
pcboss's Avatar
Received 105 Votes on 91 Posts
If you are using individual conductors the conduit needs to be a complete system. If you are using UF cable the conduit can just be a sleeve as shown. A bushing would still be needed on the conduit ends.
