Reload this Page >
I have power, but some appliance(or part of them) won't work(short circuit)?
Old 08-06-14, 03:22 PM
K
Ok so here is my situation:
I tried installing a new light switch in my kitchen, but when I was putting the new back on, I was a bit absent minded(someone had just called me with important matter) and I forgot the turn the breaker off, so when I connecter the new light switch, there was a loud bang and a lot of sparks.
I then proceeded to turn the breaker off, plugged the light switch then turned the breaker baack on .
But then I noticed a few weird things. All the other lights in my house take like 1-2 seconds to light up, and they look a lot dimmer.
My water heater isn't working, my dryer neither and while my electrical oven shows what time it is, no heating element seem to work.
I tried tripping all my breakers to off, then all back on but to no avail. (Also if I open two lights at the same time, one of them goes even dimmer. )
WHAT HAVE I DONE WRONG. (Sorry for the caps, I'm freaking out. )
Help please and thanks for the time you're giving me.
Old 08-06-14, 03:47 PM
ray2047's Avatar
You need to turn the main breaker all the way off and then on. If no main breaker in the panel with the branch circuit breakers check next to the meter or look for another panel.
Old 08-06-14, 04:00 PM
K
Assuming I find this main breaker, would that be the solution to my problem?
Old 08-06-14, 04:31 PM
turn ALL breakers off then on again.............if you have 2 single pole 50 or 60 amp breakers tied together wirh a handle tie,or wire,or nail.............make sure both turn off then back on
you are looking for the larger breaker that turns off the rest of the lights.
Old 08-06-14, 04:36 PM
Received 1 Upvote on 1 Post
It looks like you lost one phase of your incoming 240 V power. Do you have any 120 V circuits that also aren't working at all this? You should probably see that also if you lost a phase of your incoming power.
Old 08-06-14, 05:35 PM
ray2047's Avatar
We won't know till you try it. Fixing electrical is a process of trial and error starting with the most likely. Look for a breaker at the top or bottom that has "100" or "200" on the handle.
Example, actual panel may be slightly different.
Old 08-06-14, 06:08 PM
ray......give him a photo of a split bus panel...maybe
Old 08-06-14, 06:42 PM
ray2047's Avatar
Good point but I thought he had 240 appliances not working correctly:
Or perhaps the 240 breakers aren't in the right place.
Old 08-06-14, 07:53 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
What country are you in? Your problem sounds to me as if you lost a leg feeding your panel....OR....you have a fusible main disconnect and/or blew a main fuse on one leg.
Old 08-06-14, 08:30 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
To johnsc, some prefer to mount all the doubles at the top or bottom of the panel as a preference. The gap does not mean it is a split bus panel.
