dinning room recepticles
Old 08-07-14, 04:35 PM
I have question about dinning room outlets. I ran separate circuit 12/2 for dinning room. I connected 3 outlets that are not in dinning room are . The room I connected is next to the main door in the hallway. He calls these room family room and also of that circuit is outlet for outside, which I will put on WR gfci. My question is if the inspector will let it go or fail me if I feed other outlets of that dinning room circuit?
Old 08-07-14, 04:55 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
The dining room receptacles are restricted to the kitchen, dining and pantry areas. You have a code violation as described.
Old 08-07-14, 05:26 PM
bigboypete's Avatar
The dining circuit is one of two small appliance circuits that are required in your kitchen. As PCBOSS stated, you have a code violation there and will likely fail an inspection depending on how thorough the AHJ is.
