outlet wiring
Old 08-07-14, 05:56 PM
D
outlet wiring
I am wiring in a dead end outlet into a closet.The Romex will just go up to it and stop there. Just 1 piece of Romex.
THe outlet I am coming off of has the typical wire in and out to the next outlet. The 4 pinch holes are used. There isnt a problem with me using the screws on the side to go up to my dead end outlet is there???? it would save me from doing a bunch of wire nut connections...
Old 08-07-14, 06:00 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You can use the screws or pigtail all 3 conductors together with a short piece of wire to the receptacle.
The existing box may be too small to add another cable. Also the NM cannot be subject to physical damage where run in the closet
Old 08-07-14, 06:02 PM
F
If by "pinch holes" you mean the back stabs it is very poor practice to do what you propose. Make the proper pigtail connections and it will be a far better job.
Old 08-08-14, 11:41 AM
D
I wired the outlet with both wires on the bottom screws of the outlet correctly and a solid ground. When I tested it
with the tester it said open ground. So I moved the hot up to the top screw position and it came back correct on the tester. Why would that make a difference.???
Old 08-08-14, 11:53 AM
pcboss's Avatar
Moving a hot wire between the top and bottom screw should make no difference. It has nothing to do with the grounding.
Old 08-08-14, 02:23 PM
D
I didnt think so.. it was just loose grounds twisted by hand ...by the builder...
it took me 3 hours to get in 1 outlet after numerous hassles....
Old 08-08-14, 02:26 PM
pcboss's Avatar
The ground should be connected with a wire but or crimp cap. They should not just depend on twisting.
