Hot neutral reversed but wiring correct
Just bought an old NYC apartment built in the 60's. I believe it was updated in the 80's, but not really sure.
My surge protector indicated building fault wiring,and hot neutral reversed in all outlets except the kitchen and the window ac units, so I started doing a little investigating.
First, I wanted to verify I have a good ground to earth. I did not see any ground wires in my outlets, and suspect the outlet box is grounded itself. I ran a jumper from the circuit breaker box chassis to all of my outlet grounds and they all showed continuity. I think the grounds are all ok.
The first outlet that I wanted to inspect, that was indicating hot neutral reversed, I went ahead and pulled it out. To my surprise, the wiring colors look correct. The black is going to the narrow slot, and white wire to the wide slot. The odd part is that the kitchen outlet that tested good, also had the correct wire color polarity.
I then wanted to determine the polarity of my faulty outlet. I plugged an extension cord into the known good kitchen outlet, ran it and set it on the floor next to my reverse polarity outlet. I put my multimeter probe into the extension cord wide slot, and the other multimeter probe into the narrow slot on the faulty outlet, and I see no voltage. I remove the lead from the narrow slot and insert into the wide, and I see 124V. Thus, probing from wide to wide slot shows a voltage. To me, this confirms that the outlet has reversed polarity.
However, I am still confused as to why. Recall that all the wiring colors at every outlet were color coded properly (black going to narrow slot), but only a couple outlets had correct polarity voltage. Would this mean it was wired wrong at the circuit breaker box for most of the outlets and the others were done correctly? I have no way to tell, as I only have access to the circuit breaker switches, and cannot see any wiring, and am not going to attempt to pull the box out. It looks like it has not been disrupted in along time, and I am not going to do it myself.
Just looking for some input here. Wondering if I should just swap the wires that show hot neutral reverse, or have an electrician come out and look. It seems easy enough, but I am not sure if I could have more issues than I realize.
Thanks
Thanks
I have 120 between wide and ground and zero between narrow and ground.
I cannot check the wires at the panel. No access. It's recessed into the wall and looks like it's never been pulled out.
Here is a pic. I guess I shouldn't have said I don't have access. I really mean that I don't know if I want to pull it out. I see the 4 screws, but it looks as if it hasn't been disrupted in a very long time and I don't know if it's a good idea for a novice to try.
I have 120 between wide and narrow. Same as between wide and ground.
This is an old nyc apartment. All I have within my apartment is in that pic. Have no idea what may be attached or not in another part of the building.
Someone mentioned that it may be an open neutral. Is this likely, and can a circuit tester determine that?
Even though I own it? I bought the apartment/Coop.
