Surface Mount Conduit Switch Box
Old 08-12-14, 04:42 AM
A
Im going to install the conduit for a 3 way light in my basement stairwell. The conduit will be surface mounted along the stairway wall. I need a switch box at the top and bottom of the stairs. Not interested in wiremold.
Should I use a handybox for the switch boxes or something else?
Old 08-12-14, 04:49 AM
THE GRAY PVC BOX YOU USE OUTDOORS with pvc conduit gives a nice and safe look......clean look.they take a standard plate.
Old 08-12-14, 05:15 AM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Are you planning on metal conduit or pvc? How are your bending skills?
Old 08-12-14, 05:19 AM
A
No PVC... metal required. What type of metal switch box should I use?
Old 08-12-14, 10:04 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
I would use a 1900 box (4 inch square) with a raised switch cover.
https://www.google.com/search?q=1900...w=1024&bih=655
Old 08-12-14, 10:17 AM
A
I was going to use 1900 boxes but instead I went with the 4" boxes with the rounded corners for exposed work. Or would you also consider that a 1900 box?
Old 08-12-14, 10:35 AM
CasualJoe's Avatar
A 1900 box is 4 inches square. Some have square corners and some have rounded corners, it depends on how the box was manufactured. Look at the first link I posted in post #5, you'll see both types of 1900 boxes in the images. There is also such a thing as a 2 gang handy box that is 4 inches square and looks a lot like a 1900 box, but the raised 1900 device covers will not fit them. The 2 gang handy box is relatively rare, I have never seen one at a supply house before.
