Photos of Old Outlet. What am I Dealing With?
Old 08-12-14, 07:21 PM
B
Would like to change to 3 prong. Not sure what I'm dealing with here (Yes amateur, trying to learn!)
#3 & #4 were on one post? Is #5 the ground?
How/what order should wires attach to a modern 3 prong (bedroom)?
Thanks!!
1, 2 White.
3, 4 Black.
5 is Maroon & plastic
Old 08-12-14, 07:41 PM
wirenut 3,4,and5 and pigtail a black wire. wirenut 1 and 2 with a white pigtail. hookup a gfi outlet using the line lugs. black on the brass screw .........white on the silver screw.
Old 08-12-14, 07:47 PM
Is #5 the ground?
is screw 3,4 connected to screw 5...if it is it is hot.
is screw 5 connected to the frame of the outlet...then wire 5 is ground and does not join 3,4 ........but is put on the green screw.
Old 08-12-14, 08:07 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
1, 2 White.
3, 4 Black.
Your numbering of the wires with the corresponding numbers on the receptacle terminals indicate reversed polarity. You need to use a meter to determine which group of wires should be hot and which group of wires is neutral.
Old 08-12-14, 08:34 PM
B
ALSO, the main room light switch controls the top slot in outlet. ...the whole room seems to run through this outlet.
Old 08-12-14, 09:37 PM
Received 3,892 Upvotes on 3,489 Posts
In the picture you either inadvertently flipped the receptacle over or it was wired wrong.
The white wires connect to the side of the receptacle with the larger slot.
We need to see the large slot side of the receptacle to see if the terminal are tied together.
You do not have any ground wire sticking out of the box.
You will need to check from 3/4 to the box to see if you measure 120vac.
If you do not measure 120v to the box then you can't use a standard 3 prong receptacle.
The purple should be a switched hot.
3 and 4 get connected together and should be always hot.
Old 08-12-14, 09:41 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
It looks like you have conduit here. If so it would be best to pull new wires in there.
Old 08-12-14, 10:19 PM
Remember Ray.... he'll need to split the receptacle if everything works out.
Old 08-13-14, 03:25 AM
ray2047's Avatar
My mistake. Was assuming both sides had bridges in place. My post has been removed.
Old 08-13-14, 09:29 AM
brake (remove the jumper) between the brass screws
5 goes to one brass screw and the switch will work half the outlet.
pigtail 3 and 4 to the other brass screw.
put 1 and 2 on the silver screws...NO NOT brake the tab on the silver screws
Old 08-13-14, 09:32 AM
john.... you are assuming that the neutrals were tied together on the old receptacle. It would probably be best to wait for a confirmation of that first.
Old 08-13-14, 09:45 AM
yes.....yes........PJmax is correct...
look at the outlet...screws 1 and 2....is the tab between the 2 screws still intack or is it gone.
keep the new outlet the same way.
Last edited by ray2047; 08-14-14 at 08:50 AM. Reason: Remove unneeded content. Original archived.
