Reload this Page >
How to wire two lights, two switches and one outlet together?
Old 08-14-14, 08:24 AM
E
Let there be light! You've done it, my friend! The mystery combination has been solved and we have power and lights! Thanks for all your help, Ray (and others)! I learned a lot from this experience (and hopefully others will learn from this). Number one, make a diagram of the original wiring pattern before disconnecting anything. And secondly, don't bite off more than you can chew. If it weren't for this forum I would have eventually had to call a licensed electrician to help. And thank goodness we didn't have a need to summons the fire department either! I will be praising this forum via social broadcast to let others know how helpful it is! I was going to upload a pic of the installed lights but the uploader is acting up. I try again later. Thanks again, Ray!
Old 08-14-14, 09:00 AM
E
Name:  DSCN1070 (640x343).jpg
Size:  19.2 KB here we go! thanks so much, Ray! I can see clearly now the lights are on!
  #43
Old 08-14-14, 09:14 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Glad you got it. Thanks for letting us know but you need to thank Joe too. He's the one who saw the 2-conductor cable in the 2-gang box. I couldn't see it at first even when he pointed it out.
  #44
Old 08-14-14, 09:35 AM
E
Thanks go out to Joe and Ray for saving the day! Good karma to you!
  #45
Old 08-14-14, 06:17 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
Glad you got it working.
