Tandem to Reguler Socket Switch for AC
Old 08-13-14, 09:21 AM
E
Hello!
I was hoping to try and setup a remote switch for my Air conditioner in my apartment, easy enough right? Unfortunately after examining my air conditioning unit I noticed that it is not a traditional wall plug so now I am forced to buy an adapter in order for this to work.
I have an idea of how I think the setup would work but I would like to double check to ensure that I am not going to be blowing anything up or destroying anything by having a setup like this. (No sparks flying when I plug it in)
My thought is that I will need to take the Air Conditioner Plug, and go into an adapter, and from the adapter into a Belkin switch. I am just concerned to whether or not this will be safe for the apartment and the outlet.
AC Plug: [ It appears to have a built in fuse? Any thoughts or concerns about that ]
Size:  18.4 KBName:  ACPlug1.jpg
Size:  19.8 KBName:  ACPlug2.jpg
Adapter: amazon link for product information/specifications
Belkin Switch: amazon link for product information/specifications
Any and all information is GREATLY appreciated as to whether or not this setup would function appropriately and safely in my apartment.
Old 08-13-14, 10:07 AM
ray2047's Avatar
That is a 240 volt control module. If your AC is 120 volts it won't work.
Old 08-13-14, 07:09 PM
Tolyn Ironhand's Avatar
Received 676 Upvotes on 573 Posts
Ray was close. You A/C appears to be 240 volts. The Belkin Switch is for running 120 volt devices.
The final answer is still the same, it won't work.
Old 08-13-14, 07:12 PM
ray2047's Avatar
Thanks for the correction. I misunderstood his pictures.
