What adapter/mudring do I need?
I have a 4" square metal box mounted on the backside of 3/4" thick paneling.
I would like to mount a light fixture (like a lantern of some sort) to the front side.
What type of mud ring/adapter do I need to accommodate a fixture?
also
The hole cut in the paneling is sized for 4" box. With the mudring on, will a fixture cover the hole completely?
also
No, the fixture won't cover the 4x4 hole. The mudring Steel City 4 in. Square Mud Ring-52C312-25R at The Home Depot should have been installed on the box and the circle cut out so only it protrudes from the paneling.
Is there an adapter to cover the hole? Or do I just have to find a fixture with a large enough base?
yes..........................yes............................................................................................................
Cant replace that piece of panel.However, can I cut a 6x6 square from a piece of 1/4" plywood (or another kind of material??) affix it over the 4x4 hole and then cut the circle for the mudring out of it?
At that point, the panel would be 3/4" thick and the extra 1/4" means I need to find a mudring sized at 1" raised.
I know there are rules about being close to combustible material so I better ask you.
also
also
make a pattern of the round hole and the hole cut in the paneling.
take the pattern with you to a big box store.
it should be easy to fine a wall fixture that will cover the hole in paneling.
