Adding an outlet
Old 08-15-14, 12:53 PM
F
Adding an outlet
Hi, Hung my new LED TV on the wall, next step hide the ugly wires! I am adding an outlet about 3 feet higher than one already there so it is behind the TV. Unfortunately, when i took the plate off, there are no cutout holes in the existing new construction box so i can join the wires. Should I drill a hole in the plastic box so I can run the new wire?
Old 08-15-14, 01:16 PM
Handyone's Avatar
Take a small flashlight and look at the back of the box. You should see 4 knockouts, 2 at outer top, and 2 at outer bottom. These are easily knocked out with a long screwdriver and hammer.
Old 08-15-14, 01:56 PM
ray2047's Avatar
Actually you should be using an old work box and recessed receptacle.
Source: Structured Home Wiring
Or use something like this:
http://www.google.com/url?sa=i&rct=j...08222835184667
Old 08-15-14, 02:36 PM
F
Hi Handy, you were right, took a hammer and screwdriver to it and the corner notched out so i can slip the wire through.
Ray, I am using the blue box for my new receptacle, I originally meant the old box that I am tying the new box into.
Thanks all for your help, ready for the next step!!!
