Long Circuit
Old 08-15-14, 04:02 PM
Long Circuit
I have a 15A circuit that is about 75' total. At about 60' there is a junction box and I would like to tap into it for another 40' run to a light fixture.
Currently this 15A circuit hold 3 can lights and 2 convience outlets.
Is the length as I suggest an issue?
Is there a simple way to do the voltage drop calculation?
Old 08-15-14, 04:39 PM
Tolyn Ironhand's Avatar
Received 882 Upvotes on 745 Posts
You have nothing to worry about for that length, wire size, and load.
If you want to do a calculation, just search on google for "voltage drop calculator"
ray2047's Avatar
Voltage drop shouldn't be a problem plus lights are very tolerant of minor voltage drops.
ECHO... Echo... echo...
