240V Hot tub wiring help
Old 08-16-14, 02:54 PM
Question 240V Hot tub wiring help
Hello,
I have a 240 volt hot tub to hook up and have a few questions. I have about a 120' total run from the main disconnect and planned on using 6/3 NM-B from the main through the interior of the house to the GFI Spa panel outside, then about #6 THWN to the tub itself. The manufacture suggests a 50 amp breaker, I believe it is a 35-40 amp draw on start up with all pumps and heater on.
This is where I'm a little confused. Its about 65' from the main to the basement wall that goes under my deck, then another 10' under the deck until where the Spa disconnect will be located. I was under the impression that I cannot run the NM-B wire in conduit the last 10' under the deck because that is only rated for interior use. So what can I do to keep it legal and up to code between the basement wall and the Spa disconnect under the deck?
Thanks.
Old 08-16-14, 03:04 PM
Tolyn Ironhand's Avatar
Received 862 Upvotes on 725 Posts
Welcome to the forums!
You are correct, you can not run NM-b outside even of it is in conduit. Your choices are to install a pull box inside the house, or under the deck, and make the change there to a wet rated wiring method such as THWN to the disconnect.
As a note: #8 THWN installed in conduit is rated for 50 amps. If you want to run #6 that's fine too.
Old 08-16-14, 03:24 PM
Where do you mount a pull box? Inside or outside or does it not matter.
Old 08-16-14, 03:48 PM
Received 3,892 Upvotes on 3,489 Posts
You could mount it right to the house and bring the wire in the back.
You could also mount it inside and run your conduit thru the wall.
Old 08-16-14, 03:49 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
You can bring the cable into the back of the box or transition inside before exiting the house.
Old 08-16-14, 04:10 PM
An indoor box will likely be less expensive then an outdoor rated one.
Old 08-16-14, 07:19 PM
Thanks for the all the help, i greatly appreciate the assistance.
