Transfer Switch
Old 08-17-14, 03:48 PM
Transfer Switch
Separated from: http://www.doityourself.com/forum/el...-30-inlet.html
Roger, I am about to get a transfer switch for my house and I will be in the same spot as you. Did you get this worked out? Does it run only half your transfer switch since there is only 1 hot in the TT-30 plug?
I wonder if I can tie the two hots from the receptacle together. The generator has breakers on it. Heh... well if you guys don't hear back from me, I probably electrocuted myself.
Old 08-17-14, 05:04 PM
ray2047's Avatar
Roger has not been on line since November of 2013 so it is unlikely he will respond. Instead give us the full details of your problem and we will try to help. To avoid confusion I have moved your question to its own thread.
