gfci outlet not working
Old 08-18-14, 03:22 PM
Storm went through a few nites ago and the GFCI in kitchen pop. This GFCI has three loads and the phone is connected to the GFCI. outlet. if I have the loads on it will blow the breaker in the elec. box. I have checked the three outlets and fine no problems with them. If I connect only the two wires I have power in in the GFCI. whats going on These are all only about a year and half old. Working fine until now. Nothing else was effect in the house. We have one other GFCI in our bathroom and its good.
Old 08-18-14, 05:54 PM
Geochurchi's Avatar
Received 159 Upvotes on 145 Posts
Will the breaker reset with the 3 loads disconnected? If so plug one load in at a time and see what happens.
Geo
Old 08-18-14, 05:58 PM
test the breaker and circuit by removing the GFCI outlet...........wirenut the blacks, and the whites, and the grounds.............
unplug the phone...........will the breaker hold........
if it does .plug in a load....................if the breaker holds i would change the GFCI outlet
