Daisychaining junction boxes
Old 08-18-14, 05:26 PM
D
I currently have 3 exterior GFCIs (R1, R2 and R3) wired up to a junction box (J) as follows (20A circuit):
All the wiring is exposed in the basement.
I want to add another GFCI (R4) on the opposite side external wall.
I can't see any practical difference between the following two approaches but I'm not sure if there is any code governing the use of daisy-chained junction boxes? I have enough slack wire in the existing P->J wire run that I can introduce a new junction box.
Add second junction box
Chain through new receptacle
Old 08-18-14, 05:33 PM
either way is fine with the NEC.
Old 08-18-14, 08:46 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
If you place the gfi at R4 and wire R1, R2, and R3 from the load terminal you will only need one gfi.
Old 08-19-14, 08:21 AM
D
I didn't go into a lot of unnecessary detail. There was already a GFCI at R4 but it was wired to the washing machine circuit (not by me). Also, I'm fine doing like you say in bathrooms/kitchens etc but I'm not so keen on it when the receptacles are some distance apart (the pictures I posted were not to scale).
Old 08-19-14, 08:53 AM
pcboss's Avatar
The laundry circuit should not have other outlets.
Old 08-19-14, 10:53 AM
D
Which is why I'm moving it. Anyways, thanks to johnsc for answering my question.
