Need help with wall switch please!
Old 08-19-14, 03:53 PM
K
I have a 2-switch box: one runs over-sink light, one runs disposal. At least until disposal was switched on, heard a cracking sound. Disposal kept running until unplugged. The plan was to replace both switches. Replaced light switch and light worked. Replaced disposal switch, now neither works. Just noticed that there's a bare copper wire on the disposal side......Here's the setup: light switch has 3 black wires. Disposal switch has black, white and the newly discovered bare wire. Somebody please help before I have to call one of my brothers-in-law (both electricians) for help. That's last resort stuff....
Old 08-19-14, 04:02 PM
Handyone's Avatar
An electrician will be able to answer this. I just wanted to give you a quick reply and warn you that this box will contain (most likely) 2 circuits. Ensure you shut off power to both disposal circuit and light circuit.
Old 08-19-14, 04:11 PM
K
Power is off now....1 breaker for each switch.
Old 08-19-14, 04:40 PM
ray2047's Avatar
That is not relevant to this discussion but when the problem is solved you need to be sure it is connected per code.
Is one back stabbed? Is there a group of white wires connected only to each other in the back of the box? Does the garbage disposer have a receptacle or is it hard wired. Either way tell us if there are two 2-conductor cables in the wall junction box or receptacle box.
Old 08-19-14, 05:04 PM
K
Yes, there's a group of white wires in the back of the box. Not sure what 2-conductor wires are. Any way to post a picture here?
Old 08-19-14, 05:09 PM
K
Photo is attached, hope that helps.
Old 08-19-14, 05:39 PM
ray2047's Avatar
Not 2-conductor wire, 2 conductor cable. A cable containing two wires plus a ground wire on newer cables. A cable is two or more wires (not counting ground) in a metallic or non metallic sheath. Did you disturb the wires on the switch for the light? Do you have a multimeter, preferably analog? Need to see a picture of the junction box in the wall at the garbage disposal.
Old 08-19-14, 06:28 PM
K
There's just the outlet that the disposal plugs into under the sink. Is that what you're talking about? Sorry if I'm ignorant about this stuff. And I've got a voltage/continuity detector, Southwire 41160S
Old 08-19-14, 06:38 PM
ray2047's Avatar
Yes that receptacle.
Not really any good for real testing. If we need to test you will need a cheap ($8-$15) analog (not digital) multimeter. First though tell us the wiring at the garbage disposal receptacle.
Terminology: Outlet is any place electric can be tapped. Three examples are lights, switches, and receptacles. Receptacles are a female device that takes a male plug.
