HELP, 3 way switch with knob and tube
Old 08-20-14, 09:24 AM
B
Exclamation HELP, 3 way switch with knob and tube
Was hoping someone could fill in the 'magic' section i labeled on this photo. I'm looking to re-wire but would to understand how this 3 way could be currently working in my home.
Thanks everyone.
Old 08-20-14, 09:39 AM
ray2047's Avatar
Your probably missing a junction box. Check the attic.
Old 08-20-14, 09:44 AM
Received 3,886 Upvotes on 3,483 Posts
Three way wired as a switch leg to a possibly hidden junction box.
Old 08-20-14, 11:18 AM
A
Received 272 Upvotes on 248 Posts
How were the switches wired up originally?
Be sure that the wire that used to be connected to the common terminal (usually stained dark) of the old 3 way switch is connected to the common terminal of the new switch.
Otherwise the wires are connected up to the new switch the same way as for the old switch.
Old 08-21-14, 07:02 AM
B
This is on the middle level of a 2 story .
Old 08-21-14, 07:05 AM
B
not new yet
Hi Allan, there is no 'new' yet. When I get around to figuring out how in the world im going to fish to those fixtures I'll be wiring it correctly. I was trying to understand even with the potential for a hidden junction box how this was working.
Old 08-21-14, 07:34 AM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Other than out of curiosity, why do you care?
Old 08-22-14, 08:20 AM
B
well considering the only K&T was at the light... i was hoping to piggy back on the new 14/2-14/3 NDM and only do what was required instead of abandoning what looks to be mostly new wiring.
Old 08-22-14, 09:16 AM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
This might be a dead-end three way. Can you check for continuity between the ends of the three wire cables?
