Homeline circuit breaker installation
Old 08-22-14, 04:35 PM
I installed new HOMELINE breaker.
I hooked the plastic end first and pushed the breaker onto the busbar.
How hard or how much force should it get to clamp down on the bus?
Like when it snaps into place is that good enough or are you supposed to forcefully push down on it?
I assume they just snap and don't have a pressure or torque value like the screw?
Old 08-22-14, 04:44 PM
the front should be flush with the ones beside it
Old 08-23-14, 07:12 AM
Tolyn Ironhand's Avatar
Received 866 Upvotes on 729 Posts
I have found aluminum bus panels will require more force to seat a breaker then a cooper bus panel will. The end result should be as John describes it.
