Replacing a switch/outlet with a single pole timer
Old 08-26-14, 07:07 AM
C
Could anyone offer some guidance for replacing the existing outlet/switch combo with just a single pole mechanical timer?
The outlet and switch operate independently, so I imagine I will have to cap off the outlet wires. I'm not really sure which is which, and what connects where. See the attached pictures for existing wiring conditions and the timer wiring.
Old 08-26-14, 07:14 AM
ray2047's Avatar
Is there a tab between two screws on one side of the switch/receptacle?
Old 08-26-14, 07:33 AM
C
No there's not. The outlet works regardless if the switch is on or off.
Old 08-26-14, 07:41 AM
ray2047's Avatar
So you are saying the switch is a switch loop? That could be a problem. You would not have a neutral for the switch. Yes a neutral for the receptacle but you probably can't by code use a separately derived neutral. You might need to do some rewiring at the light.
Old 08-26-14, 07:46 AM
C
Each cable (one yellow and one white) each has a white and black wire coming from it (pic 3). I assume this means that the switch and receptacle each have a neutral?
Old 08-26-14, 08:00 AM
ray2047's Avatar
If the neutrals are not connected to to each other the that is incorrect. The white connected to the switch is not a neutral. See my diagram above.
That may indicate another problem. What size is the breaker? What gauge is the white cable.
This is not a mechanical timer. It is an electronic timer with a neutral but you wrote:
Old 08-26-14, 08:42 AM
C
The neutrals are connected to each other via the bottom left screw at the outlet. And yes, you are correct it is not a mechanical timer, rather a single pole electronic.
Would this wiring work with my situation?
Old 08-26-14, 09:17 AM
ray2047's Avatar
The wiring in your diagram is correct but the yellow cable indicates this may be on a 20 amp breaker. If the white cable is #14 the breaker needs to be changed to 15 amps.
P.S. Good job on the diagram.
