Clarity on Some Basics
Old 08-28-14, 07:41 PM
R
So from what I understand voltage remains the same in a parallel circuit and current remains the same in a series circuit. If I am correct then the following would be true?
Incandescent Light Bulb
Volts = 4.9
Amps = .3
Resistance = 16.3
Watts = 1.47
Power Source
AC->DC Wall Adapter
Volts = 5.0
Amps = 7.0
Watts = 35
If hooked up in a series I could use 23 bulbs (7 amps divided by .3 amps)?
I guess what I don't get is that if this is true I couldn't hook up 2 bulbs to the same adapter in a series because there is only 5 volts of power, correct? If I wanted to run them in a series I would need a 100v adapter rated at .3 amps?
Old 08-28-14, 07:47 PM
Received 3,897 Upvotes on 3,494 Posts
That is correct.
The bulb needs a certain voltage to light. You add the voltage up of each light in the series loop to determine the voltage needed to run the loop.
You would need to parallel the lamps. That would be 7A / .3 = 23 lamps.
The lamps in series would be 4.9v x 23 = 113v
Old 08-28-14, 08:51 PM
R
I guess I'm confused on how the amps play a role. I was working through a book and the example was hooking up a 3 watt LED to a 9 volt battery. So it wouldn't burn the LED out you had to run a resistor in the series. That makes sense since you need to dissipate the 6 volts that aren't necessary. But, the LED only requires .02 amps and battery produces 500ma. Will the LED only draw the .02 amps it needs and ignore the rest? Does the resistor not have an effect on the amperage?
Old 09-03-14, 08:28 PM
R
Sorry, can anyone answer this?
Old 09-04-14, 12:53 AM
Sure..... the resistor definitely has an effect on the amperage.
To figure the resistor value you need to know the following....
1) supply voltage (9v)
2) the diode's forward voltage (2v for red)
3) the diode's forward current. (.02 or 20ma.)
The resistor needed would be around 390 ohms.
You aren't dissipating 6 volts. You are limiting the circuit current flow to 20ma.
