NEMA L14-30R vs NEMA 14-50R
Old 08-29-14, 10:58 AM
W
Question NEMA L14-30R vs NEMA 14-50R
I recently purchased a 7500 running watt portable gen-set that has 1 NEMA L14-30R 120/240 30amp receptacle and 1 NEMA 14-50R 120/240 50 amp receptacle and have a question. If you do the math 7500 watts / 240 volts = 31.25 amps. How can the NEMA 14-50R be rated at 120/240 50 amps?
Old 08-29-14, 11:21 AM
W
Received 17 Votes on 16 Posts
Generator
The wattage rating determines the generator output.
The two receptacles give you a choice on how you connect to the generator.
Old 08-29-14, 02:07 PM
W
If the generator is rated at a maximum output of 31.25 amps then why use a 50 amp receptacle?
Old 08-29-14, 06:48 PM
CasualJoe's Avatar
Received 85 Votes on 75 Posts
Good question. What is the brand and model number of the generator?
Old 08-30-14, 01:05 AM
Justin Smith's Avatar
If you're using the generator to power your house via a transfer switch or interlock, use the L14-30R.(If equipped) The 14-50R is most likely there for rv'ers or other portable power applications so you don't need an adaptor.
