Splitting 200AMP service to 2 - 100AMP Panels
Old 09-01-14, 07:11 AM
R
I have an older house that I moved onto my property and I have installed baseboard heat into. I bought a 100AMP panel for the basboard. The pole has 200AMP breaker on it and Double ought running into an empty panel box in the crawl space. I would like to divide the 200AMP double into 2 100 amps circuits to feed the panels... Was thinking of some type of fusible link.
Old 09-01-14, 07:32 AM
ray2047's Avatar
How high is the crawl space? Here it would be less than 4 feet or less and unsuitable for any panel. Assuming the panel is 200 amp and it is rated for two 100 amp breakers put two breakers in it.
Old 09-01-14, 07:46 AM
R
It is around 5 feet.. my 13 year old son can stand in it. It is an empty panel box.. nothing in it.. I would like to mount whatever I could use in it.
