Receptacles on 15A Circuit
Old 09-02-14, 12:34 PM
D
Hello All,
I have four 4 foot fluorescent hanging lights with power cords attached that I want to hang in my shop. I want to run emt with #14 thhn to the ceiling and install receptacles on a 15A circuit. These would be controlled by a wall switch. I know it's preferred to have receptacles on a 20A circuit. My question is: Does the NEC allow me to install these receptacles in the ceiling for lights on a 15A breaker? I assume the first receptacle in the series will have to be a GFCI? Thanks in advance!
Old 09-02-14, 12:46 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
No prohibition. Amperage of the circuit is determined by the potential load that will be placed on it.
Old 09-02-14, 12:56 PM
Tolyn Ironhand's Avatar
Received 882 Upvotes on 745 Posts
If in a garage, (or garage like) location yes. However the GFCI is required to be readily accessible, meaning it needs to be able to be accessed without a ladder.
Old 09-02-14, 12:58 PM
chandler's Avatar
You could also protect the entire circuit with a GFCI breaker.
Old 09-02-14, 01:17 PM
ray2047's Avatar
Or a two gang switch box with a switch and a deadface GFCI or a GFCI switch.
Old 09-02-14, 04:23 PM
D
Thanks guys, I appreciate all of the info. I believe I'll go with the GFCI breaker.
Old 09-03-14, 05:06 AM
pcboss's Avatar
Received 196 Upvotes on 172 Posts
A GFI receptacle is about 1/3 the cost of the breaker.
