Solar powered fan project
Received 0 Votes
Hi guys,
I'd like to build some solar powered fans for my garage air vents
I have a bunch of 140mm pc fans I'd like to use (they have red, black and yellow cables going into a 3 pin connector). here are my questions:
- Can anyone recommend a small solar panel that would be ideal?
- How do i connect the wires from the solar panel to the fan? (sorry, newbie here)
- Can a single solar panel power multiple fans? If so, how would i wire this together?
- Can excess energy not required by the fan be used to power a battery, and then the battery power the fan over night? If so how do I wire this together?
Appreciate any help
Cheers,
Steve
Appreciate any help
Cheers,
Steve
Temporarily Suspended
Received 0 Votes
Solar fan - Wikipedia, the free encyclopedia
I doubt that anyone here has done it but there is a site that might get you started.
I've done it in a long about way. I had a panel charging a 12 volt deep cycle AGM battery then a transformer/power supply convert the 12 volts to 5 to supply the computer fans. Everything connected directly to the battery.
I did the project because I had all the parts lying around and I was bored one weekend. It worked and every time I checked the fans were running but compared to AC powered fans the computer fans were so wimpy to be almost useless. It was a fun little project but I would not spend money to buy the components to do it in my workshop.
