Reload this Page >
Grounding attic antenna to existing grounding electrode bonding
Old 09-03-14, 07:22 PM
I have a case where my home has two ground rods on opposite sides (long story). There is a #4 solid copper bonding conductor running through the attic of the garage to bond them together.
I have a cell phone booster antenna at the top (inside the roof) of my garage attic. Can I simply run a ground wire from that antenna and connect it to the bonding conductor running through the attic rather than running the antenna ground all the way to one of the the ground rods?
If so, what is the acceptable method of connecting the antenna ground wire (I will be using #8 solid copper) to the existing bonding conductor in the attic?
Thanks!
Old 09-03-14, 09:26 PM
yes
use a split bolt. google " split bolt "
Old 09-04-14, 06:27 AM
Thanks -- This will make the job much easier...
