lamp post
Old 09-04-14, 05:36 PM
B
lamp post
Customer tells me she is going through a lot of bulbs on lamp post light.Anyone have any thoughts?
Old 09-04-14, 05:38 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Aside from having too high voltage supply ( it happens), she could try rough duty bulbs. They are rated at 130 volts and have a thicker filament. They give off a little less light, but will last a longer time....Priorities.
Old 09-04-14, 05:45 PM
pcboss's Avatar
Received 194 Upvotes on 170 Posts
Loose connection s, heat and vibration are other reasons for short bulb life.
Old 09-04-14, 06:54 PM
Tolyn Ironhand's Avatar
Received 861 Upvotes on 724 Posts
Changing it to a long life bulb, such as an LED, might be a good choice too.
Old 09-04-14, 08:01 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
Except for the ones rated for 120 volts. Yes, they do have a heavy filament and provide fewer lumens. I would use a self ballasted compact fluorescent lamp it it were me.
Old 09-04-14, 08:09 PM
Justin Smith's Avatar
Received 1 Upvote on 1 Post
First things I would try is changing the socket and also check to see if it's a ballasted fixture they were once common. You'll need to take the ballast out if that's the case.
