Adding to 20A pump circuit
Old 09-05-14, 05:25 PM
A
I have a 20A sump pump circuit. It accommodates a 1/2 hp pump and less than 10W from a water softener. I would like add a 1/3 hp drain pump to this circuit... can I do it safely?
Old 09-05-14, 06:07 PM
CasualJoe's Avatar
Received 186 Upvotes on 167 Posts
can I do it safely?
That would depend on your skill level and knowledge of codes for a compliant and safe installation. If it were mine, I would put the softener on a different circuit. Will it work? Probably will.
Old 09-05-14, 06:14 PM
A
The softener takes about 5w. I wasn't asking about the installation either, the outlet is already there.... I was wondering about the load.
Old 09-05-14, 06:20 PM
CasualJoe's Avatar
Ohh...well, why didn't you say so? Sure it will work, but I'd still put the softener on a different circuit. Electronics don't generally like being on a motor circuit, but you could try it and see.
Old 09-06-14, 03:00 AM
A
Softener has a manual timer, no electronics. Its also been on the sump circuit for years working like this.
Old 09-06-14, 03:56 AM
yes. the two pumps add up to under 10 amps,
