Upgrading To 200 AMP Panel
Separated from:http://www.doityourself.com/forum/el...ter-panel.html
Interesting, I am pondering a very similar thing. I have 100A service currently, but want to add central air and possibly some electric heat, so I want to upgrade to 200A service. In my case the existing 100A panel is in a very space constrained area, with not enough room to expand to a larger panel (and frankly not enough room for a second panel in the closet it is in). I found this box (linked below) and thought it would solve my problem nicely in that it can mount outside, to then feed the existing panel plus a few heavy duty loads moved into it (well pump, new heat, new AC compressor, etc). But I don't know if these type of things are allowed in NY (upstate, not NYC)?
Eaton 200 Amp 4-Space 8-Circuit EUSERC BR Type Main Breaker Meter Breaker Ranch Panel-MBER48B200BTS at The Home Depot
Your power company should have a list of approved metering equipment available. Check to see if that is on the list.
That panel you linked to only has four full size spaces. That may only allow you to connect two 240vac loads.
Yes, too few spaces. This one has a lot : Square D by Schneider Electric 200 Amp 20-Space 40-Circuit Outdoor Overhead Service CSED Value Pack-SO2040VP at The Home Depot
My provider is National Grid. I looked around but I can't find a list from them of approved metering equipment.
