Another GFCI Circuit Issue from a Newbie
Received 0 Votes
I have the following circuit in my home :
5 outlets on the same 15 amp circuit :
Garage GFCI
Outside Front Yard GFCI
First floor bathroom non-GFCI
Second floor bathroom non-GFCI
Second floor bathroom #2 GFCI
The GFCI in the garage keeps tripping, and taking out service on the other outlets. The circuit breaker is not tripped. Sometimes I can reset the GFCI's and other times I cannot.
I initially replaced the GFCI in the garage thinking it went bad, but that didn't help. I also replaced the Outside front yard GFCI outlet - in that case the original was a 20A GFCI outlet that I replaced with a 15A GFCI outlet.
Based on advice I've read in other posts on this forum it sounds like this whole circuit is suspect. Is this something that can be dealt with by a relatively unexperienced DIYer like myself, or is it time to call in the pros?
Garage GFCI
If they are all on the same breaker either change all but the first to non GFCI receptacles fed from the load side of the first or make all connections on each to line side unless it protects a down stream non GFCI receptacle.
Received 0 Votes
Mitch17,
That's right. I assumed the previous owners knew what they were doing so I've just replaced GFCI with GFCI, except for that note I made about replacing a 20A GFCI with a 15A GFCI for the outdoor one.
Thanks for your time.
Received 0 Votes
mitch17,
Ok, I think I understand. Generally speaking - should each bathroom be on it's own circuit/breaker? Maybe the outside outlet as well that will be used for yard power tools.etc? Just wondering if I should suck it up and get the overall wiring corrected. Pretty sure I have capacity in the electrical box.
Thanks again for your advice,
-JV
-JV
FYI, in 1978 GFCI protection was only required for bathroom receptacles and for outside receptacles with direct grade access. Small appliance branch circuits, garages and unfinished basements were added to the list much later.
