Induction Hob Wiring Help
Hi guys
I'm from Singapore and I'm trying to wire up my induction hob to the provided cable.
I notice that the 2 live connections on the hob have like a copper brackets that bring the 2 connections together. Do I have to remove this copper bracket before fixing the the 2 live wires?
The same thing goes for the neutral wire
There are 2 connections that are brought together by another copper bracket.
Since I only have 1 neutral wire, do I just connect it to either of the connections without removing the bracket?
This is mostly a North American forum so most here won't be familiar with your wiring or even know what a hob is. I only no because I looked up the last time we had a foreign poster use the term. That's what we call a cook top.
I don't have a clue what you are describing. Can you post pictures? http://www.doityourself.com/forum/li...-pictures.html
