Replacing a Federal Pacific Breaker Panel w/ 40 Circuits?
Received 0 Votes
I have to replace an old Federal Pacific (
) breaker panel being used in a 20 unit apartment building. Each apartment has two single 40amp breakers in the current panel. Also, the panel is 50 inches high and 12 inches wide. The height is crucial because there are four banks of electrical meters next to the panel and the wiring comes in at all four levels. The original cover of the FP box is missing, so I don't know how many total amps the new panel needs to be. Is anyone familiar enough with these old FP panels to suggest a replacement panel that is 48-50 inches in height and will handle 40, 40 amp breakers? Many thanks.
Assuming each apartment does have a 40 amp feed it is too little to meet today's electrical needs so probably every thing need to be replaced, especially if the subpanels are FPE.
Received 0 Votes
That would be wrong. Assuming each apartment has a subpanel that should be one 2-pole breaker.
We looked and in the basement panel, each unit has two wires and two separate 40 amp breakers.
There are also breakers in the individual apartment units (20 amps in there).
Of course as PCBoss said this is not a DIY project. All we can do is help you understand what an electrician will need to do.
