GFCI outlet not working
Old 09-16-14, 01:46 PM
K
I have a GFCI outlet that doesn’t work in our bathroom. It has never worked since moving in to the house. I have replaced it and the new one doesn’t work either. It all looks wired properly as far as I can tell. Any ideas why it wouldn't be working or what I can check?
Old 09-16-14, 01:50 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
Check to see that the wires from the power cable are connected to the LINE screws on the GFCI. It is possible it was just wired incorrectly. Is there more than one cable entering the box?
Old 09-16-14, 07:28 PM
CasualJoe's Avatar
Received 185 Upvotes on 166 Posts
You may not have 120 volts to it. You need both a good 120 volt hot wire and a good neutral wire. Use a meter and test the voltage hot-to-neutral and hot-to-ground and let us know what you have.
