Generator cable
Generator cable
Hi. I am going to install a Generlink on the meter on my house and will need to use a 90ft cable to connect to my generator.
Instead of me having to drag 90ft of cable arpund my garage to my generator in 4ft of snow, i want to permanently install a cable in my garage with 1 receptacle on each end of the garage. So when the power goes out i will plug a cable from my generlink to my garage, and on the other end of my garage i will plug a shorter cable from the other receptacle to my generator. So i guess i permanently want to install a generator quality extension cord in my garage..
Looking a. #6 or #8 wire to compensate for voltage drop. Generator and generlink would have L14-30 plugs.
Will this work? Or will too many cords plugging into each other affect the quality of power?
Any advice appreciated.
You can purchase a Generlink without an inlet, and instead hard wire conduit, Romex, etc. right to the Generlink and have a remote-mounted inlet. The Reliance 30A inlets work with up to #6 wire.
