Cam-Lok Mounting
Cam-Lok Mounting
I just ordered a set of panel-mount cam-lok plugs so I don't have to lug around a 40' 2/4 cord attached to my big mobile panel. Can I mount them directly through the steel of the panel, or is that a no-no because of inductive heating? If that's a no-no, can I cut a rectangular hole in the panel and mount them on Aluminum? Thanks, guys.
The piece I posted above is from Crouse-Hinds.
I've seen them mounted in steel and in aluminum plates. Most portable racks have them on an aluminum plate but most of the genny trucks, I've seen, have them in steel.
I believe I too have seen them mounted directly to the steel of a disconnect switch. I'm trying to recall, but I'm 95% certain they were directly mounted to the disconnect and not to a secondary aluminum plate.
It looks like I can just put them right through the panel, and I can probably get away without any reinforcement unless my hole saw messes up those darn concentric knockouts.
Received 0 Votes
Cam-Loc
Cam-Loc connectors are designed to be mounted through metal as they are protected by their insulation. The NEC 300.20(B) requires a slot to cut between each phase hole passing through metal with magnetic properties. We have used the Red insulating material that is used in switchboard construction as a panel where we mount the Cam-Loc units. Never tried aluminum but the Informationa Note in the 2014 code would appear to say it's ok.
