Electrical, Gas & Ground Line over Baths Stubs
Hi
We are signed up with a builder for a single family home with an unfinished basement. The main electrical panel is located in the basement and the power line that is brought from outside enters just above a bath stub. See attached picture. The main gas line, a grounding line and the AC unit lines are also around the same area. Will this be an issue when we finish that wall which will be a bathroom. Does it pass code?
The builder's representative (sales contact) conveniently says " it would interfere in anyway with the bathroom" I am not sue about it.
Thanks for your input
Aks
Aks
Welcome to the forums!
Electrical is in the wall so it is not an issue. You can have gas and electrical cables in the same space without issue.
Your sales guy is correct. Everything else looks OK to me as well.
