30 amp 240v circuit with 120v outlet.
Old 09-20-14, 07:11 PM
D
Received 1 Upvote on 1 Post
Let's say I need a 240v circuit. I run 10-3 to my 240v receptacle. Can I then install a 120v receptacle using the neutral wire one one of the hots from the 10-3?
Old 09-20-14, 07:15 PM
chandler's Avatar
Received 9 Upvotes on 8 Posts
In theory, yes. In practicality, no. You have 30 amp OCP, which will be too much for the 120 volt receptacle, and it would be a bear bending 10 gauge wire inside a box and connect it to the receptacle.
Old 09-20-14, 07:55 PM
ray2047's Avatar
Though not recommending it you could use a fused receptacle with a 15 amp fuse and probably meet code.
Image source: quizlet.com
Old 09-20-14, 10:24 PM
Justin Smith's Avatar
Who said he's not using a 30A 120V receptacle?
Assuming you use a 30A receptacle, you can do that no problem.
Old 09-21-14, 04:37 AM
chandler's Avatar
True, but walk around your house and write down the number of 30 amp 120 volt receptacles you have. Or the practical applications.
