3-Way Switch Question
I have a 3-way switch that runs my garage lights. each switch has 3 wires: Red (Line), Black (Load), and White (presumably traveler). I am wanting to replace them with light switches like this:
3-Way Z-Wave Light Kit
Here are a few videos of my switch boxes:
Outside Switch Box
Inside Switch Box
Trying to figure out how to get this to work with the new switches. The main switch on the new set has four connections: load, line, neutral, and traveler.
The Aux switch only has 2 connections: Traveler and Neutral. After some reading, it appears that the Aux switch only relays back to the main to do the switching, so it doesn't actually do any work.
Any help on getting this working is much appreciated!!
Thanks.
Outside Switch Box
Inside Switch Box
Thanks.
Just to clarify what you have on a three way switch....you have LINE (usually black) on one switch which introduces voltage to the system. You have two travelers, usually red and white. Unless there was a neutral in the switch box, the new switches won't work. the other switch will have LOAD (again, usually black) going to your lighting as well as your two travelers. Does power come in at the light fixtures or at one of the switches?
If this is your setup, then you have no neutral at either switch for the Z Wave to work. Replacing the 3 wire cable on the left using a 4 wire cable, you can extend the neutral to the switch box.
So I need to replace the wire from the fixture to the switch box with a 4 wire at both ends?
Ok. So I'm considering just doing a complete rewire of this. I would be ok only having one switch. Any suggestions on the right way to do this? Or maybe a diagram for reference?
You might want to pick up a copy of 'wiring simplified' I have one that is 30+ yrs old and while I don't refer to it often, anytime I'm confused or need verification it really comes in handy.
Here is how you would do it by running power to one switch and abandoning power in at the light.
Does not include second switch in the box. I will address that if you decide to go this way.
Thanks for the advice. I'll definitely pick a copy of that up. The diagram is very helpful. I'm about to pull this apart and see exactly what I have and go from there. I'll let you know how it turns out.
