Shower light.
Old 09-24-14, 05:34 PM
D
Received 1 Upvote on 1 Post
Shower light.
Wiring simplified mentions some very specific type of lighting that can't be within a certain distance of a tub/shower. Am I able to put in a recessed light that has a trim with a lens in it inside the shower?
Old 09-24-14, 05:53 PM
Received 4,049 Upvotes on 3,632 Posts
Yes..... it needs to be a trim with a lens.
I usually install the stainless steel trim with the glass lens for my customers.
What did they mention.
Old 09-24-14, 06:06 PM
pcboss's Avatar
Received 201 Upvotes on 176 Posts
The trim just needs to be rated for a damp or wet location. There are open bulb trims for showers.
Old 09-24-14, 06:35 PM
I would highly recommend a closed lens trim to keep the moisture/steam penetration down.
Old 09-26-14, 05:50 PM
D
Pendant, ceiling paddle fans, and track lighting.
The ceiling height is very low. That won't affect anything? I'll make sure it is GFCI protected.
Good point about steam. I'll make sure I get an IC can as well.
Old 09-26-14, 06:09 PM
Definitely an IC can especially if it's in an attic.
Ceiling height is usually not an issue and having it on a GFI is a good idea.
Old 09-27-14, 08:24 AM
pcboss's Avatar
GFI protection is allowed, but is not required for lighting.
