connecting multiple grounds in junction box
Old 09-26-14, 07:16 PM
Q
Received 1 Upvote on 1 Post
I need to connect 3 separate grounds in a junction box.
The box has 4 screws at the back.
Can I just connect reach ground to a separate screw or should all grounds be directly connected to each other?
As it's a metal junction box I presume it doesn't matter as any screw will ground to the other.
Old 09-26-14, 07:18 PM
Received 3,760 Upvotes on 3,371 Posts
You should connect one wire to an installed green ground screw in the back of the box and then twist all the grounds together and cover with a marette.
