2 breakers in same box or split outlet?
I'm installing a new washer and dryer and I'd like dedicated circuits for each. If I'm using a tie down bar, can I put outlets from two different breakers in the same box?
One more. Same as above, and can I put them on a split receptacle (lower powered by one circuit, upper by another)?
Thanks
Thanks
But why
If you are using a multi-wire branch circuit the handles need to be tied or a two pole breaker used.
Handyone
But why
But why
Quote from Ray above. Why? It's good you're tying breakers. But as a courtesy/warning to others, I would still take a permanent marker and mark backside of face plate "warning, this box contains two circuits".
Which begs the question, is it okay to have them on the same 120amp breaker even though the manufacturer reccos separate (dryer IS gas).
If you have two circuits on the same yoke the breaker handles must be tied (or use 2 pole breaker) regardless of whether it is a multiwire branch circuit or not.
Thanks all for the help.
Normally only one (duplex) receptacle on one breaker is used for the dryer and washer. Just run a 20 amp circuit. It should be fine. Just as long as the amps of the dryer and washer added together is 16 amps or less you should be fine. Or is this a dryer with special features like steam.
Or as others suggested just run a multiwire circuit.
Pros, if he runs a 20 amp multi wire circuit will the one receptacle rule apply requiring a NEMA 5-20R?
Now that I'm thinking about this, you may want to use 2 20A single receptacles as some washers and dryers have angled plugs. What I would personally do is run 12/3 on a 2 pole 20a breaker, into a 2 gang box feeding 2 single receptacles. Use a gfci breaker if gfci protection is required.
