Installing timer for bathroom fan... wiring help
Old 09-29-14, 09:52 PM
W
Received 3 Upvotes on 2 Posts
Installing timer for bathroom fan... wiring help please
Hi,
I'm trying to connect a Leviton LTB60-1LZ countdown timer for my bathroom fan. This is in a new build home so I am hoping the wiring is quite standard.
The documentation for the Leviton timer is available here:
http://www.leviton.com/OA_HTML/ibcGe...minisite=10251
This is for a single pole location. This model timer requires a neutral connection.
The bathroom light/fan combo is a Broan 744 recessed fan/light combo. It's probably this one: 744 Recessed Fan/Lights -Bath and Ventilation Fans - Broan
I have drawn 2 diagrams (very rudimentary!) of what I found in the wall box, and how I initially tried connecting it. There was a neutral wire in the box but it was not hooked up initially.
White=neutral
Black=line
Red=load
Green=ground
Triangle=wire screw connector
Initial finding:
First attempt:
The timer did not power on at all, so I am not sure if it is defective, my neutral is not actually neutral, or I mis-wired it.
Old 09-30-14, 07:37 AM
ray2047's Avatar
No. The cable on the left is line.
Old 09-30-14, 07:38 AM
A
Received 5 Upvotes on 4 Posts
On your fan timer, the black coming from the 2 wire cable should connect to the black on the timer. The red lead from the timer should connect to the black wire on the 3 wire cable.
Red on a device is usually the switched leg of a circuit.
Don't let the red wire in the cable throw you - it feeds the light.
Old 09-30-14, 01:11 PM
W
Thank you both @ray2047 and @aandpdan for your simultaneous comments!
Switched the wiring for the red/black and it works great. Wouldn't have risked that without the advice here though.
(I was hoping my highschool/college intro physics would help me with understanding the wiring, but... NO).
Old 09-30-14, 01:48 PM
ray2047's Avatar
Glad we could help. Thanks for letting us know.
