I'm at a standstill due to bathroom wiring dilemma!
Old 09-30-14, 05:23 AM
H
I have opened up my bath with studs and ceiling exposed. I have one power source going into the room. I have a:
1. VENTILATION FAN/Light/Night light
2. 3 switch for one gang box
3. Vanity light that I wish tied to Main Light in Fan
4. Separate shower lights
5. Single switch for shower lights
I have new 12/3 wire and 12/2 wire.
I know I'm going to split the power source to the shower light switch and to the 3 switch. Can someone look at the diagram below and tell me how to wire the 3 switch to the ventilation fan with a the power line.
Name:  Bath wiring.jpg
Close up of fan wiring diagram:
Old 09-30-14, 07:20 AM
ray2047's Avatar
I'm a bit confused. Are you trying to use one triplex switch for everything? It sounds like you may need more then the one triplex switch. Do you want every thing controlled by that switch that switch? I'd suggest a double gang box and the one triplex switch for the exhaust unit and a second duplex or triplex switch for the other lights. I would bring power into the switch box not the exhaust unit because there isn't that much room for wiring at the exhaust unit. Even at the switch a 2-gang deep box may not be enough.
Note to the wiring in your diagram is conduit not cable.
Old 09-30-14, 07:36 AM
Handyone's Avatar
Welcome.
I can tell you how to wire this, it's fairly simple. But....
Since you're down to bare studs, I would consider changing the layout first.
First, power should come into switch box as Ray said.
Second, Consider using a 3-gang switch, box. Layout as follows:
SW1 (closest to door) - Vanity Light and Fan Main Light
SW2 - Shower Lights
SW3 (2 stacked) - Night Light and Fan
Others may have a better configuration, but if possible use a larger box.
Old 09-30-14, 07:39 AM
ray2047's Avatar
Brian has given you a very good layout. I also agree a 3-gang box if at all possible.
Old 09-30-14, 07:43 AM
W
Received 63 Upvotes on 55 Posts
Switches
The diagram utilizes 2 switches. Use the third switch for the shower lights.
Pigtail vanity light into the connection for the fan light.
Sorry, guys. I am a slow typist.
Old 09-30-14, 08:05 AM
Handyone's Avatar
The diagram uses 3 switches, with the option of 2 switches by tying main light and fan together on one switch.
Black, Main Switch 1
Black, Additional Switch 1
Red, Additional Switch 2
Old 09-30-14, 08:43 AM
H
Thanks for the replies guys.
Just to clarify a bit; the original has TWO gangbox locations each singles. The first one is where the picture of the triplex is (which is where the door is) and the second box is next to the shower (where the picture of the single switch is).
The gangbox in by the door, i might be able to put in a double gang box but not a triple without some cutting of the studs which I hope to avoid.
If I go the double gang with a triplex (for the ventfan/light/nightlight) then a single for the shower lights (then vanity lights pigtailed to ventfan light like wirepuller mentioned) do I use both a 14/3 AND a 14/2 running from the triplex to the fan unit? This is the part that confuses me. Anyone mind doing a blow by blow which wire to which screw? Also where does the power line black and white go into?
Thanks!!
Old 09-30-14, 08:50 AM
H
Would this work
Do you guys think this will work?Name:  Bath wiring2.jpg
(grounds not in drawing)
Handyone's Avatar
OK,
I get it. That drawing you posted is a floor plan of the bath. I thought it was just info.
I'll get back as may others.
Old 09-30-14, 09:12 AM
Handyone's Avatar
I don't want to comment on wiring yet. It does appear you have this down.
My concern is the box at door. You will have at least the following (or more)
Power in from shower switch box
1 3 conductor cable to fan unit
1 2 conductor cable to fan unit
1 2 conductor cable to vanity light
You could eliminate one of these 2 conductor cables by joining fan light and vanity light from above.
I would still add a two gang box:
Attachment 39154
Old 09-30-14, 09:38 AM
ray2047's Avatar
I would remove that section of stud Xed out in the diagram and install a 3-gang box. You really need the room.
Yes, a bit higher but not that much and could be lower with a little more work.
Old 09-30-14, 09:48 AM
H
I agree :)
That was just what I was thinking!
Old 09-30-14, 11:17 AM
ray2047's Avatar
Looking good. Are you going to add the cross piece? If not load bearing you may not need the 1x4s just the cross piece. Suggestion: When it come time to install the box put a 2x4 flat in back to screw the box to.
So tell us your final decision on switches and we will help you with that if you need it.
Old 09-30-14, 01:17 PM
pcboss's Avatar
Received 181 Upvotes on 159 Posts
I like to use smurf tube with individual conductors from the switch to the fan unit. That way you can add the additional switched hots easily vs using cables and reidentifying whites as a hot and it cuts down on conductors in the small fan box.
